Gen II Airbag in Gen I?
SHO Mojo
West Chester, OH, USA
Correct me if I'm wrong, but the Gen II and later airbags are 2-stage? But, can they be used with a Gen I system, perhaps with a controller change?
Why am I asking? I have a sweet Gen II steering wheel ;) I want to use on my Gen I, and want to hook-up the airbag if I can.
Thanks for any input,
SHO#7
Cincinnati
OT, nice car. We should get together some time.
Mike
SHO Mojo
Changing Airbag Connectors...
OK Jelloslug, is that connector swap something I can do without having it blow up in my face? :shrug:
SHO#7 That would be a good idea, perhaps at a local event or cruise night? Looks like you have a nice stable of SHOs!
ohioshodude
SHO'ld fogy
delaware, ohio
Updateinter1
yes its possible and very easy. the dual stage air bags are a rather new idea they are in the 00 and on tauruses...
the air bag has a two wire plug but they are a smaller black plug in the genII. you can either cut and resplice the plug in the steering wheel or do as i did and replace the hole clock spring and wiring in the column and cut and splice under the dash. just make sure you unplug the battery before doing any of this or you might have a different SHOBOOM experience. :thumb:
SHO Mojo
Ah...thanks.
Hey, I understand now. I didn't know that the two stage airbags were so "new" a product. I'll give it a whirl. Unfortunately, I recently replaced the clockspring, so I'll probably cut/splice on the steering wheel end.
Good info, thanks!
ManySHOs
South Jersey
I'll add my 2 cents which doesn't mean much. Two things though:
1. The Helms (1994) states that the Rotunda air bag tester is different for pre-93's. I always assumed that this meant that the airbag system itself was different but perhaps its only the connector?
2. I sold an airbag to someone who put it in an FR500 wheel in a gen1. The next owner found that the airbag idiot light had been taped over and that the airbag had kept flowing fuses. I never had a problem with it in the 93 atx that I pulled it from. Of course, I had no practical way to test it.
So, I have no experience with this but I previously thought that the airbag systems themselves were different and therefore the bags couldn't be switched. I guess I was wrong?
I'm not telling anyone that they are wrong. Just trying to learn. :)
Ian
BigCaney
N.E. Ky
I have also been wondering about the Gen 2 steering wheels and air bags in a Gen 1 car.
So a Gen 2 steering wheel will bolt up with no modifications to a Gen 1 car and the air bag will also connect and work after I change the one connector, right?
:wave:
tinkerkathleen
