After a couple of months using the Gen 3 Konis setup that SHO Source is selling is just the the right thing for the Eibachs lowering springs. They SARCs in hard mode would still bottom out. They are using the GEN 2 Konis in GEN 3 struts which are a bit shorter.
With the Konis in the softest mode they are comparable to the SARCs and will bottom out under harsh conditions. Bump them up a notch and this goes away. They also sit about a 1/2" lower than the SARCs with Eibachs. The only thing lacking is somewhere to mount the ABS wires and the brake hose.
ABS is easily fixed with the GEN 2 clip on wire holders. The price is competitive to new SARCs which fail with the Eibachs.
and :urock:
