Gen 1 to Gen 2 body interchangability
shobhakti
n. fl
Hi all forum members
I searched but could fine no answer to wether or not a window motor mechanism from a Gen 1(91) will interchange with a Gen 2(94). if this question is redundent please point me to the proper thread. Thank you.
SHO BHAKTI
PS. we corrently own...
94 opal frost, mtx, dynomax cat back, catless y pipe 9lb flyweel with clutch master stage 1 clutch, 24frunt and 26rear swaybars, solid subframe bushings.
93 white, mtx, catless y pipe, 9lb flyweel with chutch masters stage 3 clutch, intracs/koni ajustable struts, Gen 3 brake upgrade, k&n filter, painted engine.
92 silver, mtx, stock.
92 silver, mtx, solid subframe bushings, 24frunt and 26rear swaybars.
91 tan, mtx, stock.
91 tan, mtx, stock, wrecked parts car.
shobhakti
n. fl
Thanks Ken
But the wiring at the switch is different beween the two. I havent as of yet taken out the motor from the 91 though, is there something I'm missing? Is the wiring also compatible?
SHOBhakti
shobhakti
n. fl
Job done, thanks Ken
for your help. I did not take out the regulator by drilling the rivets. Instead I bent the door out about an 1/8" just between the two top motor bolts that secure the motor to the regulator. This gives just the right amount of clearence to remove the motor. I did this on both back doors with no drilling, no damage and no further drama.
SHOBhakti
Kens1992mtxSHO
The Commonwealth
:thumb: good job. Glad to hear it all worked out. Sorry I missed your last post on the wiring.
