Gen 1 HELP!!
Bigjoey71
Gurnee, IL
Hey guys, my buddy really needs some help. He has a 90 SHO and he has been having some problems with his car. He just had the engine rebuilt and then he had to also replace the fuel system (fuel pump, filter, and fuel pump relay). Everything was going fine until yesterday.
On his way to a friends, the car began to hesitate when he applied the gas. It also died later on. I checked his car out and it is not a slight hessitation. It is a major jerking action as if the car isn't getting any gas. This jerking motion occurs in every gear. Anyone have any ideas? Please help a fellow sho-owner out.
Joe
SHO SPD
SHO member #480
Naples, Florida
Is there any chance that he washed the engine recently? If so the spark plugs/wires may be wet.
1989 Titanium pearl
CAI
K&N cone filter
Slicers (thanx to G/F)
JBL speakers (thanks Adam) ;)
G-tech times
0-60....6.61 sec.
1/[email protected] MPH
my page.. http://www.geocities.com/shospd/index
its almost here!
Bigjoey71
Gurnee, IL
The plugs and wires are both new. The engine compartment hasn't been washed either. Any other ideas?
How about Sdpatt? any ideas???
First pull the codes and check back. It's alot easier to diagnose and you'll have to do it anyway to make sure all bases are covered.
SHO SPD
SHO member #480
Naples, Florida
Since the plugs are new, check to make sure they are in the correct order, if they were put in following chiltons, they are gaurenteed to be messed up because they are wrong.
pjtoledo
'ol man in the SHO
toledo,ohio,usa
make sure the plug wires are seated, they may have loosened. It is very easy to improperly install the CPS, it may be hitting the vane and is in the process of wearing down.
Perry Toledo,Ohio
