gas spraying in engine...help
shooff1994atx
On my 4th SHO
Goldsboro, NC
i have got a 1994 taurus sho atx...i have been smelling gas lately but but never thought anything of it..i took it to a mechanic to get the oil changed and my engine started smoking...and he said not to drive it because gasoline is being spayed into the engine...sooo...what should i do? part out the car? sell it? or keep it and fix the problem..i am moving to georgia from ohio tuesday...I dont know what the problem is..the guy wants 300 bucks to take apart the engine to see what the problem is...if someone else had this same problem or knows anything please let me know..i dont want to sell my car cus i love it...but i dont wanna have a car i cant drive...
shoteen95
isn't a teen :D
Dearborn Heights, MI
well I would hope there's gas spraying into the engine:nut:
So is this an actuall leak? Perhaps where the fuel lines lead to the rails? Did you smell gas before you got your oil changed? Or did you mechanic just drip oil onto the exhaust, and then smell gas fumes from say...a bad charcoal canister and decide to try and rip you off.
This sounds sort of shady...and I personally wouldn't give that mechanic a dime.
FoeSho
Marshall, WI
Fix the problem, its easy.. find the leak, replace the part..
Thats liek saying " Oh crap, my oil needs to be changed, Lets get rid of the car"
shooff1994atx
On my 4th SHO
Goldsboro, NC
ok i went to the guy today...the problem is an o ring in the fuel pump.....he said it will cost about 300 bucks...so my next question is how hard is it to take apart the fuel pump and change out the o ring? and it is actually dripping out of the engine
Dan H
Seattle
The fuel pump is at the rear of the car in the fuel tank. I don't see how it could "spray" into/onto the engine.
You normally have to drop the fuel tank to replace the pump, although some folks have discovered you can remove the rear seat and cut a carefully measured hole through the floorpan instead.
$300 labor is a rip off to replace a fuel pump.
FoeSho
Marshall, WI
I think that procedure abotu removing the back seat and cutting a hole is more work then dropping the tank from underneath the car. Honestly, withotu ever doing it before, you can drop the tank from under the car in about 30 minutes, and that includes jacking up the car and placing the jack stands.
its sooo easy, even for beginners.
Plus do you really want another hold cut in a structural part of teh floor pan? This woudl eventually rust etc if you cut a hole under the deat, not to mention the mold that can develeop when water gets up in there.
Off Road SHO
Moderator
Wow, you need to find a mechanic that doesn't need to make a boat payment. Hook an air chuck to the schrader valve on the fuel rail and put 35 psi (no more than 35 psi) of air to the system and look for the leak. After you find the leak, and it will be obvious, get the part yourself and then ask on here how to go about fixing it. We'll talk you through it. Good luck.
Tom
FoeSho
Marshall, WI
Tom
Yeah there are alot of knowledgable guys like Tom that can help you on here..
Maybe SHOforum.com needs a "live" garage mechanics chat forum with video:)
shooff1994atx
On my 4th SHO
Goldsboro, NC
my bad.....i listen half assed...haha....ok it wasnt an o ring for the fuel pump...it was an o ring for the fuel injector...sorry...
LeddZepp8687
The Keg Rider
Naperville, IL
Thats good!
Thats not too hard at all, Atleast I dont think so.
Go to your local parts store and buy injector O ring seals, Then we can tell you how to fix it.
Is it leaking where the injector goes into the heads or where the injector is attached to the fuel rails?
