Gallons to Empty
SuperPete
PA
I seen it somewhere, can't find it now that there is a way to show GALLONS to EMPTY,
Anyone knows how?
SuperPete
PA
I was reading somewhere on the forum some time ago that there is a way to show gallons some how, can't find it now, if anyone knows how please comment.
IF you doing e30 mixing, its kind of helpful
If you rest your trip and put it in enhanced mode it will show you gallons used since you reset it.
I reset trip one every time I get fuel.
I reset trip two every time I change my oil.
SuperPete
PA
How do you put it in enhanced mode?
I do reset my trip every fill
It is in the trip settings.
SuperPete
PA
Went to the car, looked up and down the setting and trip settings, can not find that that..
Throw me a bone please :)
Thanks
802SHO
Boost > VE, MBT, Cams
Essex Junction Vermont
What does knowing gallons to empty over miles to empty mean for you? Hope that doesn’t sound like I’m being a dick. Just curious
SuperPete
PA
E30 mixing.
When you add e85 to 93 its nice to know how many gallons you have left or used to get correct mix.
802SHO
E30 mixing.
Oh! I can’t get E85 and am missing out on the E30 magic. Makes perfect sense to me now. There’s also some sort of device you can install that will tell you you’re mix as well so you don’t need to wonder. SBS has one and some others.
Pete,
It isnt hard to find. IIRC go into your trip 1 or 2. Press the right arrow button and you should see options. Either standard or enhance. Choose enhanced. It isnt hard.
Screenshot 20191102 191019 Write on PDF
SuperPete
PA
Pete,
DID that, pushing right arrow, nothing happens, see photo attached.
I was in trip 1 and 2, pressing, holding, smashing, NOTHING...
ridered74
I usually just go by the miles remaining, divide my mpg average into that, and add two gallons to the final number. It seems to work fairly accurately. My fuel IT ethanol reader always pops up almost the exact % I expect after a fillup.
