Fuse #'s
Felbdogg
Tabor, SD, USA
What are all the fuse #'s for the SHO fuse box. I didnt receive a owners manual with my SHO and was wondering what they all are. Thank you for any help.
'89 SHO
SHO94
Columbus, Ohio
Here is the information on the fuse box. Hope it helps.
Cavity. Fuse- Circuit
1. 15 Amp- High-Mount Stoplamp, Stoplamps, Front and Rear Turn
Signals, Instrument Panel Turn Indicator Lamps
2. 30 Amp- Windshield Wiper Motor, Intermittent Wiper Module,
Windshield Washer Motor
3. Not Used
4. 20 Amp- Front Park, Side Marker and Tail Lamps, "Headlamps On"
Warning Buzzer/Chime, Front Laser Lamp (Sable)
5. 15 Amp- Electronic Cluster, Rear Window Defroster Switch,
Electronic Flasher, Backup Lamps, Heated Oxygen Sensor (HO2S), Illuminated Entry Actuator/Electronic Door Lock Control Processor, Brake Interlock Solenoid
6. 15 Amp- Rear Window Wiper and Washer Motors (Wagons), Diagnostic Warning Lamp Module, Warning Chime,
Headlamp Switch Illumination (Sable), Clock Illumination, Radio Illumination, EATC Control Illumination, Power Window Relay, Speed Control Amplifier
7. 15 Amp- Air Bag Diagnostic Monitor
8. 15 Amp- Clock, Radio Memory, Glove Compartment Lamp, Luggage
Compartment Lamp, Instrument Panel Courtesy Lamps, Interior Lamps, Illuminated/Entry Actuator Electronic Door Lock Control Processor, Power Mirrors
9. 30 Amp- Blower Motor
10. 20 Amp- Flash-to-Pass, High Beam Headlamps and Indicator ³ 11. 20 Amp- Radio, Premium Sound Amplifier, Power Antenna Motor, Redundant Radio switch
12. 20 Amp- Cigar Lighters, Horn Relay, Horns Circuit Breaker
13. 5 Amp- Cluster Illumination, Radio Display, Ash Receptacle Illumination, EATC Control Display, Rear Window Defroster Switch Illumination, Rear Wiper Switch Illumination, Headlamp Switch Illumination, Clock Display, Transmission Range Indicator Illumination
14. 20 Amp- Power windows, Power moon roof
15. 10 Amp- License Plate Lamps, Side Marker and Tail Lamps
16. 5 Amp- Electronic Cluster, EATC Control
17. 15 Amp- EATC Compressor Clutch, Blend Door Actuator, A/C Compressor Clutch
18. 10 Amp- Autolamp Module, Cluster Warning Lamps, Low Oil Level Relay, Buzzer/Chime
SHO94
[This message has been edited by SHO94 (edited 11-24-2001).]
Careful Felbdogg and SHO94, the fuse circuits were different between the Gen Is and the Gen IIs. I just went through this with a 94 MTX and my 91 MTX and there were some distinct differences. I am not in a position to check for the specific changes, but there are a few.
Scott
1991, 252K miles, glass hood, police grill, SVO shifter, Catz fogs,
Eibach/Tokico/polyurethane, SHO Shop front & rear strut braces,
Class II hitch, Silver award at the SHOklahoma Car Show
SHO94
Columbus, Ohio
I did not know there was a difference. What I have listed above is for a 94 SHO from the Ford Service CD.
SHO94
Bizzy
This is from a post I did way back when but it's for a 1991...should be o.k. for an 89.
Ok...here goes....
#1-15 amp-brakelamps, engine computer, high-mounted brakelamp, speed control, turn signals.
#4-20 amp-chime for headlamps on, front parking lamp, side markers, tail lamps.
#5-15 amp-backup lamps, electronic climate control, electronic cluster, hazard flashers, ligh for the keyles entry system, rear window defroster, warning & indicator lights.
#6-15 amp-power windows, warning chimes, lights for: clock, electronic climate control, electronic cluster, radio.
#7-15 amp-air bag module, & fog lights
#8-15 amp-chime for key in ignition, clock, keye entry system, radio memory. Lights for: engine compartment, glove box, instrument panel, interior, power mirrors, trunk storage area.
#9-30 amp-electronic climate control (if it does not blow air)??
#10-20 amp-high beams, warning lights for high beams
#11-20 amp-amplifier, power antenna, radio
#13-5 amp-lights for: ashtray, cluster, gearhift indicator, electronic climate control, radio, switch for rear window defroster.
#15-10 amp-license plate lamp, side markers, tail lamp, any other optional lamps.
#16-5 amp-electronic climate control, electronic cluster
#17-10 amp-air conditioning, electronic climate control.
#18-15 amp-Autolamp on/off delay system, safety belt chime, warning lights.
I think that's it.... This is for a 1991, don't know if it's different for other years or not. Straight out of the Ford Owners guide for my car.
Proud to be an American!
Beth
'91 Plus MTX, Mostly stock
K&N Filter, Coneless
Colgan Custom Bra
Racing Series Driving Lights
Mods in the works
Many items on wish list!
