funny noises in engine... HELP!!!
BBoiByron
Salt Lake City, Utah
hey guys... I'm new to the forum, I just bought a 1990 white mtx SHO... and when I start going from a stop it makes a weird crackling sound... I messed around with it a bunch, and you can't hear it at all from the outside... it only does it in low RPM... it doesn't do it in neutral or reverse... could this be because I don't have enough gear oil?... or an exhaust leak (I'm pretty sure there is one)...? thanks for your help guys...
Piccolo
Salt Lake SHO Club
"You got a nasty hole in your fuel rail. That's why your unloading in third." JK B. I think K is actually right on this one. That pickup coil or some coil of some sort. You need a professsional SHOer. SDPatt! Where are you!
Sounds are incredibly difficult to diagnose through a discussion fourm, but it may be the notorious SHO manual transaxle gear rattle. It comes from the cut of the gear teeth and is not a problem other than the possibly embarrasing sound. It probably would serve you well to check the level of the transaxle fluid and top it off with the recommended Type F or MERCON ATF. Search this Forum for the descritpion of the location of the fill/level check plug. Welcome to the Forum and good luck with your SHO.
snowwind1990
springtown, tx
Well....is the "crackling" in the ENGINE or in the TRANNY?......come on now. Byron, you did say ENGINE right?
shoot
And now.....you have had your wiring almost catch on fire? Have I got it right?
So the "crackling" isn't happening any longer or what? eek!
<small>[ September 17, 2002, 08:05 AM: Message edited by: snowwind1990 ]</small>
