Full Chassis upgrade pix! Not installed yet.
adidas_kn
LOWSHO
Houston Texas
Whats up everybody?!? Getting stoked and kinda freaked about my upcoming chassis/suspension upgrade. I have almost everything ready and waiting for install. I am still waiting on my reinforced rear strut mounts, Ground Control coilovers, and 8mm Taylor wires(blue) from MidwestSHO. My new extreme MM's and Quaifed/cryo'ed/shimmed SS tranny are on the way. New front lower control arms, front/rear STB's and 11.6" vented rear brakes are coming soon. Anyways here are pix of my new parts awaiting install.
All the pieces together
ALSFB's
AL rear control arms with spacer/washer/bolt kit
H-brace
ProSuspension camber adjustment strut mounts
SF recall kits
Composite HD front SB endlinks
HD solid rear SB endlinks
TPR F/R strut/tension rod bushing kits
One of my new Tokico struts(rest are still in boxes unopened)
Pix of brakes on next post. Gonna be a big install!
Later
"J"
adidas_kn
LOWSHO
Houston Texas
Yep Tokicos and coilovers as Mike at Midwest says there should be nor problem. The spring rates are 450lb fron and 350lb rear so it should be fine for a mostly street driven car driven only on occassion.
Koni's will go into the Tokico housings when the tokicos wear out.
I'm not sure what company makes the control arms as I purchased them off of TrojanMan.
Later
"J"
SHO92
Upper Freehold, NJ
The rear control arms look like the ones that Zach Leahy made a few years back. Russ at RCM doesn't sell any that look like that AFAIK.
