fuel pump
Mullet
Lake Orion, MI
I just bit the bullet and took my sho to the shop to see what was making it stumble at WOT. turns out i need a new fuel pump. Since im going to be replacing the fuel pump i figured may as well get a higher performance one. My question is what size fuel pump do you guys recommend and what is your favorite brand.
p.s. i used the search function
It really works!!
Since you used the function then you should already be familiar with the Walbro pumps most often recommended the 155lph and the 190lph. Either will do fine. For a stock setup maybe 155 would be better.
