Fuel Pump Not Working
Dr.Evil
No Dif Pin!
Sparks, Nevada
After I had a crash with the SHO, the fuel pump does not work. I tried pushing the reset button in the trunk, but it looked like it was not triggered. I messed around with it for a half hour with no luck. Is there anyway I can bypass that thing? Or does anyone have any ideas as to what else it could be?
Thanks
Matt
jbeano
Caledon, Ontario
I had the relay go bad on me once and another time a chaffed wire blew the pump fuse. You can use a digital multimeter to check for voltage and continuity through the inertia switch.
projectSHO89
SHOless In St L
The inertial switch can be bypassed simply by shorting the two wires that go to it together. That's all the switch does internally, anyway.
Steve
Dr.Evil
No Dif Pin!
Sparks, Nevada
Shorting the wires did not work. I will look for a blown fuse.
Thanks
Any other ideas?
Since it was crashed in the front, make sure the relay control module is powering the pump and work your way back after you check the fuses.
<small>[ January 03, 2003, 02:49 PM: Message edited by: luigisho ]</small>
