fuel line question
copperpacecar
pa
which line going to the motor is positive from the fuel pump and which is the return fuel line the one that enters the side or the regulator or the other line. car is a 95 3.0 sho
NotSoSlowSHO
Gas is $$ WALK!
Moscow, IDASHO!
From the tank goes to the regulator, that is on the fuel rail closest to the firewall.
Is that what you are asking??
frosho
WOLFMAN
Tyngsboro, MA
Fuel goes to the front rail first, then loops to the rear, then hits the regulator before going back to the tank. The regulator keeps pressure up by restricting flow, so it has to be downstream of the injectors.
copperpacecar
pa
thanks guys for the help...cut both lines and honestly didnt expect them to be different sizes and got careless and didnt check so as im installing the new motor and fuel lines i didnt know where to put what
