Fuel injectors misbehaving
V6Hova
trenton,nj
In order to check if you are getting electricity to the injector you have to take off the manifold, right? It seems i'm not getting 12v at any of the injectors in the key on position. Am i missing something? I put a meter in the wire harness and I'm getting nothing. ALso no fuel from any of the injectors.Could it be a bad EEC? Any one have any clues for someone who has had his SHO in the garage for longer than it's been on the road. frown
SHO--ripper
928 Euro
winsted,CT
Any codes? I'm assuming the car doesn't run. Does your fuel pump prime? If sho is there any FP at the rail?
V6Hova
trenton,nj
No codes, the car was running(until i took the intake manifold off), and the fuel pressure is fine. However after a cylinder balance test it came up with a weak #2 cylinder. I'm still trying to figue out which one that is. I've seen a few different examples.
V6Hova
trenton,nj
hey thanks. That'd be the one that the fuel injector seemed to not be working on.
