fuel filter location
zerg1024
NJ
i was wondering where the fuel filter is so i can replace it?
somedude_001
Western NY
I it is just infront of the right rear tire, its a small cylinder you'll see it
go out and buy one so you know what it looks like since your going to replace it anyway.
it is removed by popping out the 2 white tabs and sliding the lines away from the filter.
Ishodu
When you go to replace the filter trip the crash sensor in the trunk then run your car until it stalls before removing the clips on the fuel rail or you will get some gas spraying everywhere.
SHOdownTN
Texas
Don't forget too losen the clamp or it will be a pain to get off and watchout for fuel to come out. I had almost a quart come out on my arm. I Did mine on the ground with a floor jack so I had to lay in it to put the new one on.
Get a drainpan or something to catch the fuel in so you don't have to lay in it.
