1994 Ford Taurus SHO (receipts and history log kept since purchased)
85,000 miles 2nd owner
Known issues
1. Headliner in rear
3. Driver door
a. ¾ button on keypad does not work
b. Keyhole light does not work
(in the process of fixing all of these)
Upgraded/updated
1. 24mm front sway bar with Moog blue bushings
2. 26mm rear sway bar with Moog blue bushings
3. 60k service
a. Valve cover gaskets and bolt seals
b. Ford spark plugs and Taylor wires
c. Cam seals and front/rear crank seals
d. Cam sensor and crank sensor
e. Oil pan gasket
f. Tranny pan gasket
g. Torque converter seal
h. New power steering pump
i. *New* Ford alternator
j. Serpentine belt
k. Dayco timing belt
l. Bosch 02 sensors
4. Kicker front door speakers
5. Kicker back dash speakers
6. New subwoofer
7. Tape deck to headphone adapter included
8. New fuel filter
9. Cubby under radio
10. New BF Goodrich tires
11. Hard button EATC
I bought the car from an elderly couple in their 80's. The back-story goes like this...8yrs ago the husband died and the wife was admitted into a nursing home and the SHO was parked in the garage where it lived its' whole life (yes, sat for 8yrs).
I drove the car home as it was from Atlanta, GA to Lafayette, LA and began the repairs to all the dry-rotted rubber gaskets and seals.
There is no rust on the car and only (1) small ding on the driver front fender.
Asking $3,500
Check the links...
http://www.shoforum.com/showthread.php?t=127592
http://www.shoforum.com/showthread.php?t=127425
http://www.shoforum.com/showthread.php?t=127388
Known issues
3. Driver door
Upgraded/updated
3. 60k service
e. Oil pan gasket
j. Serpentine belt
l. Bosch 02 sensors
6. New subwoofer
8. New fuel filter
Asking $3,500
Check the links...
