nomov8sho
Junkyard Rat
No, not tire-smoking burnouts...
My '97 has developed a loud squeal / screech noise that does not SEEM to be brakes. Here are the symptoms:
-Loud sustained noise
-Happens when making a right-hand turn
-Definitely coming from the left front (driver side) wheel
-Started a couple days ago, only when car was cold, now happens every right turn
-Seems to get a bit louder when I hit the gas more
-does NOT change with application of brakes
-Front wheel seems to have some play (more than pass side), but lugs are tight
My first thought is bad wheel bearing but I've never heard one squeal like that. No "clickety-clickety" noise while driving, no "clunk" going around corners.
That entire hub / bearing assembly was replaced and new brakes put on all around about 4 months ago by a shop, after an accident.
Any other theories to look at before I tear somebody a new one for shoddy product / workmanship? Any ideas are appreciated...
Thanks,
-Josh
Thanks,
-Josh
