I am new to this forum and I am replacing my front struts on my 2010 SHO. I am trying to remove the nut off the lower ball joint and the ball joint bolt spins. There is a hex shape at the top of the bolt but it is rounded off. A 10 mm wrench is too small and a 11 mm is too big. A vise grip will hold it but it gets in the way of removing the nut. I do not want to cut the bolt and have to replace the entire control arm. I tried using a jack under the control arm to put pressure on the ball joint to keep it from spinning , but no luck it still spins. Any suggestions are appreciated.
Thank you,
Mike
Thank you,
Mike
