Front Strut Removal Question
Funmart6
my name is mud
Auburn, Alabama
When removing the front strut to change the mount or bearing, does the spring have to be compressed in order to change the bearing or mount?
Funmart6
my name is mud
Auburn, Alabama
Thanks, I have really got to change the mount or bearing on my driver's side strut because the squeaking is driving me crazy, only squeaks when I turn to the left though, but it sounds horrendous.
Silvapain
Limestone, IL
It's been a while since I pulled a front strut apart, but IIRC the bearings are separate from the mounts - the bearings can be replaced without spring compressors but the mounts can't.
Someone please correct me if I'm wrong.
Mr95Gl
Mr Tire Iron
Brooklyn, N.Y.
The bearing is separate from the mount, but you still need to compress the spring to remove the bearing.
bacernate
97 MONEY PIT
Denver, Colorado
struts very rarely squeek. take a closer look at the outer tie rods to see if they are the source of your noise. they get rusted up since they cannot be greased.
