front speaker grill removal
Cornhead
Binghamton, NY, US
I picked up a 95 ATX last week, love it so far. My drivers side speaker in the door is out. I would like to swap it with the other door speaker to test it. Do you just pry the grill off? I started to take it off. It came loose on top, but it doesn't seem to go back on where it is loose. Thought I would be safe and ask for advice before proceeding.
LOUDSHO92
Sponsoring Vendor
Rancho Cucamonga, CA
You have to pry off the door panel. The grills are not supposed to come off. There are a couple of screws that first need to come off. They are fairly obvious, one is in the handle, one in the map holder, one by the side view mirror and I forget if there are anymore. After that there are the plastic "screws" holding in the door. Someone said its possible to slide it off after some acrobatics but I just pried off the door. If you pry it you will only damage the screws which can be replaced. Their are 14 plastic "screws". I got like 40 of them from Ford for a couple of dollars. As for the grills you are going to have to glue them or plastic weld them back on.
92 White SHO
HiRevs Competion Clutch
SHOSHOP Engine Mounts
Koni Shocks
StrutTower Braces
UD Pullies
Awesome Sound System
crystizel
