front radio speakers cutting out....
joshsquiresmi
Michigan
So I've noticed everytime I stop my front speakers cut off....as soon as I hit the gas they start working again. They work when I am coasting, braking, anytime the car is in motion, just not when stopped.
Anyone have any ideas? Or has this happened to anyone?
joshsquiresmi
Michigan
i figured that...but didn't make much sense for it to cut off only when stopped and turn on as soon as I hit the gas.......It's not like jerks or anything is being made to make some wires touch or ground. It's definitely weird.
deercrusher
never running!
PA
it might be that your head unit's amplifier section is going bad - ie.. when you hit the gas the voltage spikes a little bit - and the circuit for your front amplifier output shorts out. Just a thought.....
joshsquiresmi
Michigan
If this was happening in mine, which is completely stock.....it would be happening at one of the amplifiers in the back then correct?
