Front Motor Mounts Shot - anything else while under the hood?
VampyreGTX
IL
My front MM finally gave up this weekend and I will probably pick up a front rear set of the ShoSource mounts; however, any other recommendations on preventive maintenance I should do while under the hood? I have no performance mods at the moment (won't really be able to afford any until next year probably) so I'm limited more to the replacement of stock parts for durability purposes.
I have a '92 MTX with only 93K on it.... only other issues at the moment is needing to replace the clutch on the A/C compressor and a loose/ripped hose in the windsheild washing tubing somewhere.
93rev2sev
Hockeytown
Yep, dropping the coolant is needed so you might as well make sure the cooling system is ready for summer with a flush and a t-stat.
If the lower hose looks nasty or is bulging at the ends you might take this time to replace it also. There's another hose number that will fit if you can't find a "sho" lower rad hose...do a search for "lower radiator hose" ...it'll turn up.
Tom
