Front Impact - No start
oh_SHO
Ohio
I am trying to get my parts car to run. It was hit in the front-right corner. I got her to crank but the FP isn't priming. I changed the IRCM (thing under the fan shroud) with a known good one. No change. I did notice that the CEL doesn't come on at all... I tried projectSHO's grounding of the FP test circuit with no success. I am going to run out and see if pin8 has battery voltage to PCM. What are the chances that the PCM is dead? Any other suggestions? I know this is just like a recent thread but I can't find it! A link would be cool too. Thanks!!
wood_e
The dude
Ames, IA
Maybe the inertia switch (fuel pump cutoff) in the trunk got tripped. Try pushing in the button and seeing if that works
oh_SHO
Ohio
Ok, there is power to pin8 which means the PCM is getting power. I tried the EEC self test put got nothing...
oh_SHO
Ohio
That was the first thing I tried. I forgot to mention it in my first post. It was tripped but isn't now... I also forgot to mention that all the fuses are good.
