shoon
cliTaurus
Have kind of an odd problem, and am on a tight budget right now... just spent $300 ish in parts on a new tank and fuel pump.
While driving along I hear rattling, like somethings floating.. the front end was tight when I checked it on the hoist with the car up in the air, check the 12 and 6 o clock, no play same with the 3 and 9 o clock positions, everything was solid.
however.. It felt like front end and was driving me nuts, so I bounced the suspension to try and find the noise, couldnt find it.
so I reef on the top of the tire back and forth and to my surprise, I find out I can adjust my camber a few degrees by hand
The passenger side is the culprit, the drivers side is tight.
im trying to figure out if I need a new strut or strut and strut mount? Anyone try monroe quickstruts?
was thinking about sensatracks, keep the same coil springs and mounts for now as an economy fix.
As far as steering goes there is no memory steer, grinding, binding or popping.. I know when most strut mounts go the coil spring binds and unravels as you try and turn the wheel before popping sometimes.., but I don't get that.
Thinking maybe the plunger part of the strut went and is bouncing around inside the strut, maybe thats why I couldn't find any play when it was on the hoist because the strut was fully expanded..
I removed the upper strut mount cap, and while pulling the wheel in and out, the rod part of the strut with the nut was angling in and out.. not moving straight back and forth like a solid strut would if that makes sense to anyone.
Anyone experience anything similar? Any thoughts?
