Front end issues
SHOtime3
DohcYamahammer
Knoxville, TN.
I haven't had time to jack up the car and look at it yet but here is what happening. 1) Torque steer is really aggresive pulls hard left on a hard launch from a stop or a roll. 2) When I had my wheels rotated they said that they could wiggle the left front when it's off the ground. 3) When it's cold out at low speed when I turn the steering wheel tight the front end makes a popping and groaning noises. What are some things I should look for and replace?
Thanks, T
ty91sho
EVRYDAYHUSTLIN'
st.cloud MN
the two or three that i think it could be is the tirerod ends, balljoints, and strut rod bushings. or it could mean that you have joined the broken subframe club. just jack up the car and look around and have someone move the tire when you lookin for some kind of movement or clunking.
Armstrong
Berea, Ohio
yea, it's most likely a bad tie rod or ball joint. that's how you check for worn tierods or ball joints... you grab the tire and try to wiggle it back and forth.
