Front End Creaking Like An Old Door
SW SHO
Boss Man
Santa Fe, NM
When turning(especially right) up an incline, like a driveway or business, the front end creaks.
Confirm this is the sub frame?
Will Sub Frame Connectors solve this, or is it the struts (which need replacing badly)?
Lance
ghostrider
Mt Juliet, TN
It could also be strut mount bearings. I've got the same sound coming from the front end of my SHO and a friend who is a mechanic said it is probably that. Don't know yet though because I haven't gotten all the parts together to get it all replaced.
I put my money on the outer tie rod end(s). Remove the wheel and tire and try to rotate the tie rod end with you hand or a wrench. If it squeaks, you found your old door.
Slo-Sho
It wasn't me!
Crossroads, CNY
sdpatt:
I second this, try turning your wheel full lock (either way) and grab the outer tie rod and twist it.
SW SHO
Boss Man
Santa Fe, NM
Thanks for the tips guys. Saddly, my SHO probably needs every suspension part updated.
It is good to know what to replace though. Thanks!
Lance thumbs_u
If it is the OEM tie rod ends, you don't necessarily have to replace them to stop the squeak. I used a small hypo needle and wheel bearing grease to inject the rubber boot full of fresh grease on one SHO with really squeaky rod ends. They loosesned up and got very quiet again. He won't need new tie rod ends (or even a re-greasing) fr quite a while.
Scott
