ISHOU
I know wrong forum but I'm hoping for more lookers since there are fewer of us SHO owners around. I've owned my 94 for 13 years. I replaced inner/outer tie rods, strut assemblies, control arms, and strut rod bushings 7 years ago. Have been getting a clunk in front on hard braking only. After searching here thought where the strut rod enters the sub frame was the issue. Took it to a shop for only the second time I've owned it. The young techs pointed out a bad ball joint which could cause the issue. I wanted to eliminate the strut rod. They said it would be really hard to replace the bushing after removing it, really??? An older tech came over and I showed him on this website what I thought was going on. Question: where the strut rod goes through the subframe, the donut for lack of better words was not attached to the frame and I thought this is what needed welding, am I wrong? He said he couldn't weld it because it was "tin". He suggested the Moog kit I mentioned and of course a new control arm. After he tighten up the bushing, the clunk is gone.Your help is appreciated.
