Fahrzeug
Rent this space
Hey everyone! Sorry this is such a long thread but I would like some feedback on this.
I've done a lot of research and staring at pictures (it's better than buying this stuff) of the Freestar and Taurus knuckles and hub/bearing assemblies and I figured this swap could possibly be done with a Gen 3. The Gen 3/4 use almost all the same suspension/steering components to the best of my knowledge.
I had made a thread on taurusclub, but not much to my surprise, nobody cared. I think I may have stumbled onto something that could help all of us out with wheel choices. It would be sweet to see a Gen 3/4 on BBS's or even the 18" '08-09 Taurus chrome wheels!
Now, I could be completely off on what I found. I really think it's a major possibility!
So, I'm asking here because everyone here is a lot more technical and knows a lot more than the crowd over there. Could it be done, I know it has in the past with a redrilling of hubs in the front and a redrill and Probe GT hubs in the back.
Anyway, here is my thread copied right from there:
I'm not sure if anyone has asked this or even tried it, I was wondering if it was even possible. I know all of us are not impressed by the selection of 5x108 wheels. 5x114 would open up a million possibilities for us Gen 3/4 owners if this conversion is possible.
I know we can use Windstar wheels and things like that since it was built on a Taurus platform. I figured they left it mostly the same when they switched to the Freestar, but I'm not 100% if it's still on the Taurus platform. It could be on the Five Hundred/Freestyle platform.
The front hubs look almost identical but the major difference is the ABS sensor is actually integrated in the bearing it looks like (pics from Rockauto.com) Knuckle differences could also be a problem. I know the Taurus knuckle has the bracket for the ABS sensor while the Freestar does not.
Freestar w/abs
Taurus w/abs
I'm sure there is a way to bolt them up, if the sizes are exactly the same.
The other problem you would run into is rotors/pads. The easiest way is to just get your front/rear rotors/drums redrilled to 5x114, but that just seems like a pain in the ass.
Taurus Front Rotor
Freestar Front Rotor
I see a slight difference in the rotor hat height, but that could be compensating for the extra width of the hub sticking out a little more. This could interfere with the knuckle and caliper.
The other issue you would run into is the rear hubs/rotors. I had heard on SHOforum that it could be possible to run Probe GT rear hubs, and redrill your rotors. By looking at the specs, you could possibly run the GT rear rotors. You would have to convert to rear disc if you didn't have it to begin with.
I also compared sizes of the rear hubs and rotors, and they are also close.
Taurus Hub w/abs
Probe GT Hub w/abs
The only differences are the exciter ring for the ABS. You could swap them if the bearing size is the same.
Taurus Rear Rotors
Probe GT Rear Rotors
The rotors are close, but really no way to tell.
Going by the sizes, there really is not much difference in the front rotors that I can see. Looks like very slight differences. The rears could be an issue with the different hub sizes. The height is almost the same.
This is just a quick thought for everyone to ponder. I know there are lots of other things to consider like caliper brackets, calipers, etc...
I know there is no way to tell if any of this will work without actually trying it first. I will really try and do some more snooping and try to pick up a couple of these hubs for cheap and try them out if I can.
-Tim
Freestar w/abs
Taurus w/abs
Taurus Front Rotor
Taurus Hub w/abs
Probe GT Hub w/abs
Taurus Rear Rotors
-Tim
