FPS now sells 24mm front and 25mm rear swaybars
GASHOGUY
JDM/DTM convert
Kennesaw, GA
Ford Performance Specialists now sells 24mm front and 25mm rear swaybars with poly bushings. Pricing is $229 for a front bar and bushings and $229 for a rear bar and bushings. Just thought I would pass it on.
Larry Maletta III
1992 SHO MTX 132k miles
195.4FWHP 192.9ft/lbs.
FPS Performance Tune,FPS Subframe Connectors, FPS Solid Subframe Bushings, FPS Reinforced Motor Mounts, FPS Cold Air Induction, Hi-Flo Cats and Y-pipe, Custom Cat Back Exhaust and Magnaflow Mufflers, GTS Headlight Covers, Colgan Bra, CB w/PA and glass mount antenna, Backlit in-dash SHO logo, PIAA 1500XT, '96 Big Brake Upgrade, Superchip
