Jr's Sho
I found out what my problem with the ignition is. The rod inside that is moved by the igniton cylinder supposely has a plastic piece or whatever that is used to pull the ignition switch off whenever the key is turned from Run backward toward Off. After watching the piece directly above the ignition switch peg, that is moved by the rod, only move to start but not backward, it seems that the only way of finding out is to tear the steering column apart. In order to remove the steering wheel, what has to come off? Both lower and upper shrouds are off but does the air bag have to be disconnected,I need whatever help anyone can offer.
<small>[ January 23, 2003, 07:22 PM: Message edited by: Jr's Sho ]</small>
