Guys, won't ignition timing make an engine run warmer than it should? i.e. too advanced or too ********. Check your timing. Also, I assume that if you replaced the ECT, you replaced it with some bargain variety from Autozone or Advanced Auto? Why not spend a few extra bucks and try the Motorcraft ECT. Like 32.19 from FPN vs. 14.99. It would make sense to me that the ECT would be the culprit since SHOLOVER mentioned that his computer reads it as 190 to 212 and then kicks the fans on. The computer's most likely not reading the sensor right because it's some replacement POS. The only reason that I say this is because I had an Autozone (Wells) temp sender fail after a year. I replaced it and magically my guage came back to working order. If the quality on something so unimportant to engine control is that **** poor, what's the quality like on something more important? Probably about the same. Especially when dealing with vital engine sensors, stick to the Ford parts. Replacements are a redesign made by some manufacturer because that way they can cut corners and they think they know better anyway. You wouldn't put Autolite plugs in your SHO, would you? So why put in a non-Motorcraft ECT? Sure you pay more for it, but the quality is the same as it was the day it rolled off the assembly line. Simply my opinion and experiences.
