Forscan Screenshots and Info
monkeyboyx
MI
Figure I post some screenshots of the Forscan software for Windows PC. I would recommend for everybody to dl and try it out. You can even do some limited module programing. This requires registration and license file, both are free for now. Minimum you will have a great check engine/ODBII scan tool. There is also a version for Android and iOS but those have limited capabilities.
This is the ODBII to USB adapter that I’m using, also the Chinese VCM clone works great with this software.
https://www.amazon.com/ELM327-Interface-CAN-BUS-Scanner-Diagnostic/dp/B017GIKXZK?ie=UTF8&colid=TN1WPWF3J9UO&coliid=I3NC5SHM1KSAFQ&ref_=wl_it_dp_o_pC_nS_ttl
How to program Central Configuration using FORScan
http://forscan.org/forum/viewtopic.php?f=6&t=1932
Standard and Extended licenses for Windows
http://forscan.org/forum/viewtopic.php?f=5&t=836
Module Build Data (As-Built) (This link might change)
https://www.motorcraftservice.com/AsBuilt
(Connecting to Vehicle and module scanning)
(DTC - Check Engine)
(Live Data)
(Module Configuration and Programming, full access only available with license file. Dangerous if you don't know what's going on. :) )
If somebody has posted this before them I'm an idiot and should learn how to use the search button.
mrhighcaliber
I wonder if its possible to disable the tpms sensors. Or, if Lowering that "Front/Rear tire place card Pressure" to zero would do the trick?
Sent from my Nexus 6 using Tapatalk
