Ford Hints at 400-HP Taurus SHO & more
SHODWN
Mother Threasa
Spencer,Ma usa
hmm, that's weird I drove an early build SHO and a Fusion Sport AWD last year that both did it. It sounds like you have the fix with fuse #14 anyways. too bad there wasn't a fuse for RWD, although from what I've heard the diff and PTO aren't designed for full power for prolonged periods of time, so it would probably grenade.
Well I can say that the guys that built the car are watching and reading this forum.. My thought but I cant confirm are that its been programed out seeing that it would blow the rear of the car up real quick. Just using short code but my car jk1 and his was jk2. I know that jk3 was also used in the 10my.
Simon, it sure would br GRATE!
markathome
2010 SHO
VA
Along the same lines...interesting read on Edmunds about this new Ecoboost in the F150 for 2011:
http://bit.ly/dcAYz1
Six Is the New Eight
Between these impressive efforts sits the new marquee engine that Ford considers the "volume" top-level choice. But it's no V8. No, this is the EcoBoost twin-turbo V6 we've been hearing about, and it's for real.
Like the Ford Flex/SHO EcoBoost engine, it displaces 3.5 liters, has direct fuel injection and is pressurized by two turbochargers. But in turning it 90 degrees, from front-drive sidewinder to a rear-drive north-south orientation, most major pieces had to be redesigned. The basic architecture is the same — bore centers, deck height, 60-degree vee angle — but the block, heads, valve covers, intake manifold and other big chunks are all-new.
And there are specific performance-oriented differences. The Flex/SHO EcoBoost has intake-only variable valve timing, but this trucked-out version can vary exhaust valve timing, too. Its twin turbochargers are made by Borg-Warner instead of Honeywell and boost pressure has been raised from 10 to 13 psi. A large air-to-air intercooler sits behind a gaping slit in the chrome bumper, with the front license-plate bracket moved off to the driver side.
What kind of output does all this new hardware generate? Try 365 hp at 5,000 rpm. Peak torque is up there — 420 lb-ft at 2,500 revs, with 90 percent of that available from 1,700-5,000 rpm. Meanwhile, the same 3.5 liters of Flex EcoBoost makes 355 hp and 350 lb-ft of torque on premium fuel. Displacement aside, please don't confuse these two motors.
bmytych
