Fog Lights.
SASHO91
Zoom Zoom
San Antonio,TX
I mean actual fog lights... you know the yellow lights... not driving lights....
:nut:
Anywho,
anyone running a set? I've been itching for some for some time now. I found a set made by APC(looks decent) that utilizes a H3 bulb. I can get the H3 bulb in 100watts, which is what i plan on doing. The housing is 2x5 and is said to have a directed beam pattern, which is not normally found in Fog lights(most use a wide pattern).
Just looking for some more insight.
I'll try and post that set im talking about.....
Not what im looking at, but i think this set would look and perform better with the 100watt'ers....
http://cgi.ebay.com/ebaymotors/SMAL...ategoryZ6755QQihZ013QQitemZ230030159270QQrdZ1
EDIT: another thing that crossed my mind was the amps. Im not sure on what the fuse panel one is. And IIRC, there is also a secondary fuse under the dash somewhere for the stock lights. Being that im gonna run 100watts (8.4amps) I am unsure if the stock wiring will hold that. I have an extra wiring harness that was used on an old setup. It has a built in relay, and IIRC, has a 20amp fuse rating.... (could be wrong) I may have to resort to using that harness if yall dont think the stock one can handle it. Or if the stock fuse rating is under the 8.4amps. (i think its a 15 amp fuse... )
SASHO91
Zoom Zoom
San Antonio,TX
IIRC, they are the 893 bulbs.... (GenII)
but dont expect any dramatic increase in illumenation.
