Fog Light/Auto lamp question
SinisterSHO
Rust free
630, IL
I know that there is a fog light mod to where you can turn your fogs on at anytime. However, I use my autolamps, and want my fog lights to still work with them. Is there any way to be able to turn my fog lights on whenever I want, but they will still turn off with the auto lamps? If I need to use a switch, that would be fine.
Also, I saw something before about someone wiring thier courtesy lights up to come on when they put the car into reverse, did you use a switch for this?
Thanks.
Yes, you need two relays that both feed the one fog light hot wire. One relay is triggered by the parking lamp (or low beam) hot wire and the other relay is feed by a switch that you can manually operate.
If you would want to ever shut them off then wire a HD switch after both relays on the hot wire going to the fogs.
The cornering light mod that come son in reverse is easy. Just wire the cornering hot wires to your gear position indicator switch reverse wire.
