Fog lamp question
reags8
Connecticut
OK I've done the search and nothing addresses what I'm looking for (most of the fog lamp related posts are for the mod.). I want to change my fog lamps to yellow over the white - actually white fog lamps are "driving lights" and not really fog lights because white reflects off fog causing even poorer visibility as opposed to yellow which cuts through fog. Has enyone tried this ? and how ? Are there yellow bulbs available and do they work with the clear lenses ? and are there yellow lenses available ? from another model car ? :confused: :confused: :confused:
Thanks
Reag
National #19
Dubuque, Iowa
bulbs
Check online or at a local parts store and they may be able to order you yellow bulbs for your factory fog lights. Or i would just say find some cheaper fog lights online or at a store that are yellow and look similar in shape and mount and wire those up.
Andy
Devin
3.Slow
Pacific Northwest
Is it just the color? I thought as a rule the reason those lights (as well as those lovely street maps) cut through fog was because they were sodium lamps.
National #19
Dubuque, Iowa
fog
That could be. But i must have misunderstood you. I thought you were just looking for "yellow" bulbs or yellow type of lights. But maybe you can find a bulb that will work the driving light and is used for foglights?
