fog lamp issues
Anonymous
Philadelphia,PA
I just change both fog lamps on my SHO and they still won't come on ...can anybody tell me what the problem could be??? thanks..........
xxxtommyxxx16
Slide or Die
Lakeland, Florida
I have the same problem on my 91, lights are new and hooked up, and switch for the lights come on. any help on the fuse location?
Racer X
SHO Pilot, Retired
Connecticut
The fuse is located in a solitary holder, under the dash near the fuse panel inside the car. Look, you'll find it.
On the year of the car, it looks like (s)he drives a Gen 2 based on their avatar.
frosho
WOLFMAN
Tyngsboro, MA
FWIW, the fuse in my old SHO was stuffed under the carpet there in the driver's foot well. So just look around the whole area until you find it.
ourd
USA
I think, most probably, the problem may be related to the switch. I would advise him to get it replaced with a new one. Also he should ensure that there is nothing wrong with the connection. If these are okay, then the problem may be related to the fuse. He should check whether the fuse is working or not. It is located under the dash near the fuse panel.
