Fog/Driving Lights
Funmart6
my name is mud
Auburn, Alabama
I want to add a set of PIAA Solitaire series 00153 driving lights. They are 36mm High X 90mm wide X 38mm deep, I figured they should fit well inside the front air dam and I will try to mount them in the lower part of the dam at the far corners.
Anyone got any suggestions on what would be the best way to wire these up, lets say I want them to come on when the parking lights are switched on, how could this be done? This would eliminate the need for an extra switch, so if it can be done that would be great.
Thanks,
A lighting relay and an in line fuse is all you need. Take the lighting power off of the engine compartment fuse box by the mega fuse using the in line fuse. Run this power to the relay and out to the lights. Tap into the parking light wire at the front lamp as the trigger for the relay. Ground things properly and you are done.
Funmart6
my name is mud
Auburn, Alabama
Thanks, the kit comes with an in-line fuse, relay, wiring harness, switch and all the hardware needed for mounting of course so maybe I will get it all together soon.
I found these lights on ebay for $19.99 new in the box!!! With shipping I paid a total of $30.55, not bad I guess for lights that retail for $137.00. These lights are oval shaped so I think they will look good on the car. They are the Plasma Ion yellow with black housings so they should also blend well being that my car is black. Can't wait to get them going.
