Fog bulb replacement in GenII?
91grnPlus
Roswell, GA
Any tips or tricks? Looks like I may need to remove the bracket to get better access to the bulb??
Thanks,
Mike
shodown220
It's Not A 5.0!
Lexington, NC
Whoa now. Just to change the bulb? I'm pretty sure all you gotta do is reach under there and pull it on out. I didn't have to remove any brackets. Stock foglights suck, even after changing bulbs. I can recommend Eurolite bulbs though. Have a nice white tint. Although you can't really tell on the road, pretty much just for looks. I would like to replace with some foglights i can see while driving. So if anyone else would chime in for any recommendations for that, that would be great.
SHOtimer
#2910
Santa Clarita, Ca
Thanks,
Mike
If I remember - you just turn the bulb and they come right out - similar to the head lights.
Doug
91grnPlus
Roswell, GA
Thanks guys...I know it sounds like a dump question....but I looked under the fascia yesterday at the bulb area and it doesn't look as easy as just popping the old one out. I'll have to take another look and let ya know!
Ace
Manning Hater!!
Norfolk Mass.
i have eurolite bulbs myself and i agree they do look better than most bulbs...
91grnPlus
Roswell, GA
Can you get those bulbs at most auto stores?
I was just told to get to the bulbs you take off the front lense!! I kept thinking they had to pop out from the back somehow!
Mike
91grnPlus
Roswell, GA
Just went outside and looked at the fogs again...I'm thinking someone added some aftermarket fogs to the car. Looks like they have mounting brackets and one even sits a little higher then the other!
shodown220
It's Not A 5.0!
Lexington, NC
how about post up some pics. stock foglights, all you do is reach behind them, twist, and pull it out. Takes no time. You must have some aftermarket ones. If you can, get some pics up.
91grnPlus
Roswell, GA
Finally got around to messing more w/the fogs today. Someone added aftermarket lights. They were all rusted to all get out so I just took both them out and am looking for some new ones.
Mike
