GotGrip?
Conversation Ruiner
Forgot to get this posted up on here after Facebook, but here we go!
Part list:
Treadstone tr8c 29x8x3.5 (you could do the standard or L model)
Universal 2.5 inch intercooler pipe kit
Ronteix:
1.75-2.5 coupler - ED90D5170L125H
2.5-3 90 degree reducer - ED90D5776L125H - there's a few sizes you want 63-76mm for drivers side cooler inlet
2.5-3 coupler - SR7663L76B - You may need 1-3 of these depending on what cooler you get, one for merge pipe and one for cooler outlet.
2.5-3 inch reducer - SR6351L76RH - Off the merge pipe
XS-Power:
2.5-3 inch merge y pipe - B076HBS9RJ
Mishimoto:
2.25-2.5 coupler MMCP-22525BK - off rear stock turbo pipe
Total part cost: around $450, could vary pending discounts/deals and shipping.
Max size cooler you can do this way before moving the rebar or condenser is 30x8x3.5, any thicker you'll run into the grill any longer you won't be able to fit couplers from what I can tell. You will need to trim the RT headlight and 1 bracket on the RT rail that holds a sensor but it can be relocated to the adjacent bracket about an inch away. If you have the K&N box you will need to cut the bottom front corner to let the intake pipe pass. Depending on the style of cooler you pick you may need to trim the core support on the drivers side to accommodate the piping, that or you can loosen the rebar a tiny bit to add some extra space. I do have plans to run the rest of the intake piping from the filter up to the turbos when I have more time.
Part list:
Ronteix:
XS-Power:
Mishimoto:
