Justin@JDM
Doing a clutch now, is it safe to resurface the flywheel, the guy at the trans shop says he "thinks" Ford says you have to replace them but it would be a lot cheaper to resurface it. So is it safe ot be done?
gmorrell said:IIRC, the FW minimum substrate thickness is cast into the back side, if it isn't, someone here can certainly look it up for you.
Make sure you have the FW Blanchard (dry) ground, don't let some know-nothing yahoo turn it on a brake lathe, the clutch lining will never seat properly.
Gary M.
