Flywheel/Flexplate
Off Road SHO
Moderator
They are normal threads. Lefty loosey, righty tighty. Clock wise to tighten, counter clockwise to loosen. If you grew up with nothing but didital clocks, I don't know what you're going to do. :)
Because it's sitting on a tire you will have to chain the flex plate to the block to keep it from turning. Use one of the flexplate-to-torque converter holes to anchor the chain. Good luck.
Tom
Xs SHO 1
Unknown
McHenry, Illinois
Those bolts must be torqued on there real good, I was having a hard time loosening them, I just wanted to make sure it was normal threaded.
Thanks!
