Fly Wheel Bolts
ice111103
I did a search and couldn't get any answer. I want to know if the flywheel bolts are the same for the ATX and MTX. I bent two of them trying to get the crank bolt off while I was doing my 3.2 swap and I need some new ones. There is an ATX in the junkyard near by I was wondering if the ATX bolts are the same or where I can buy new ones.
CerberuS
300 HP N/A SHO
Granby, QC, Canada
Not 100% sure , but i doupt it.
Cose of the flexplate being very thin , and the flywheel being thicker....(usually)
Never seen a SHO flexplate , but where the bolts are at , if its the same thickness as a mtx flywheel , it should be same bolts.
nkb93
SLO 4 SHO
Charlottesville, VA
The stock 3.2L crank to flexplate bolts are too short to be used with a 3.0L flywheel. You'd be lucky to have 2 threads holding it together.
Shoaz
Studly dood
Scottsdale, AZ
x2
The bolts are not the same, you need the correct bolts for the application as they will not interchange between ATX and MTX.
