Flex pan upgrade
MHW100
British Columbia
I'll be interested if this helps come summer time.
LilCop2002
In the South.
Ive been looking to replace mine... since it disappeared somewhere I need to.
With all the options, it looks like you got the OEM with the openings.
What part number is that?
MHW100
British Columbia
It is the OEM. I bought it from the dealer. I don't have the part number. The tech put the heat tape down and made a few minor other tweaks but was essentially a straight bolt on.
krewat
Long Island
Do NOT forget this... let us know if you notice better PTU temps or anything else.
David Miller
Lagrange, IN
If you install this and you get more cooling airflow around the rear turbo and PTU, how much extra road grime accumulates that needs cleaned off before oil changes/maintenance/repairs?
FiveLeeter918
Ortiz Performance Sales
Tulsa, OK
Mine has been on for about a year. I really haven't seen any added grime honestly.
David Miller
Lagrange, IN
That's good, I live in the snow belt, so I get to drive on salted roads 3-5 months of the year. That kind of road grime/salt/rust is what I would be worried about.
Thanks again!
Matt M PA
This is something I've been thinking about....does anyone have solid info on how much this helps?
15SHOPP
Cincinnati
I posted a while ago after I did mine. I saw a drop in temps per my Torque app. Happy I did mine and should help more once temps warm up.
