rendyx
Today I tried tightening the pinch bolt under the steering column boot, and achieved mixed results. It does seem to be the problem with my loose steering, as when the wheel is turned, it fails to turn the shaft past the bolt. I jammed a socket on, began tightening, and it was working - until the socket slipped and rounded the bolt.
My next step may be to weld on a square nut to the bolt, and either tighten it, or remove it and replace. Does anyone know if that bolt can be removed without the entire steering shaft falling apart? And does anyone else have another idea to solve this?
Another note: Any tricks to get the wheel lines up exactly right when I tighten it? This time around, there is quite a bit of slop when the wheel is turned to the left, but none when turned to the right (starting from straight steering wheel). I'd like to get the steering wheel straight if possible. Thanks!
<small>[ May 07, 2003, 03:35 PM: Message edited by: rendyx ]</small>
