I'm planning on installing a 15mm hubcentric wheel spacer onto the rear wheel hub of my 94 SHO. I've cut the fender lip by about 13mm. The problem with this is the length of the wheel studs. Way too short. So, I need to find 10-15mm longer studs. I'm persuing to solutions to this:
1. Finding longer studs which have the correct knurl size so they will fit into the stock wheel hub. So far, I've been completely unsuccessful at finding such. Do you know where to get such studs?
2. I know that longer studs are available, but they also have larger knurl diameter. So that means to drill out the current holes in the wheel hub. Is this advicable, and can I do it myself with a good heavy duty drill and high quality drill bit?
---Michael
94SHO,green,BOS2
---Michael
94SHO,green,BOS2
