first victim of AGSP32FM
wood_e
The dude
Ames, IA
I've had mine in for several thousand miles with no problems....
Petersho1
IL
I did upper 60K a month ago, just after that lost cyl#2. New wires, plugs, so I was sure it's something else. Got injectors cleaned, check coils and nothing!
I swiched spaks plugs and balance test showed diff. cyl. not working.
"Pics?" of what?
the spark plug looks like new and never working.
projectSHO89
SHOless In St L
The #2 plug is the most difficult to replace if done with the intake still atttached.
Inspect carefully to see if the insulator is damaged.
Steve
Rockledge
Pluggin' away
Connecticut
"Pics?" of what?
For a plug to not fire at all, I don't think it's unreasonable to assume that there would be some kind of visible evidence of failure somewhere on the plug. I guess what you are saying is that's not the case here. I find that very interesting.
projectSHO89
SHOless In St L
SHOZ123 said:
Even some new plugs are bad. Check it with an Ohm meter.
Indeed.
For the thread originator to declare that he/she is a "victim" of the new part numbered plug because it is a new item is somewhat laughable.
My bet would be that either the plug was damaged in some way or it was a manufacturing defect.
Just because it's factory fresh doesn't mean it's good.
Steve
bmytych
