Call_Me_crazy
I am new to SHOFORUM and new to the SHO however this is the 13th Taurus my faily
has owned since 1988.
I recently purchased a 1993 3.2 atx green with grey leather for $400.00 from a lady who went blind and hasn’t driven the car in over 4 years. The other reason the car has been sitting I was told because it was running hot and they parked it with the intension on getting it fixed and giving it to a child at a later date which never came.
I put in a new battery and starter, pulled the oil soaked plugs and she cranked right over, I then reinstalled the plugs after cleaning and re gapping and she fired right up, even on 4 year old gas! It smoked a little at first but not to much, no more than you would expect. The first thing I noticed was a slight knock, witch I first attributed to bad gas. Since then I have ran 2 tanks of premium thru and the knock has gotten less but it is evedent It’s mostly coming from the front head/valve cover area.
The car also got hot fairly quickly so I did a full flush and cleaned out as much of the system as I could. Install a few new hoses and a thermostat and refilled to no avail. Its still getting hot. I even changed the temp sensors and that did nothing. The pump appears to be working as I can see the water churning in the radiator(maybe that’s not a good way to tell) the fans kick on and that helps some what but the gauge still ends up in the red zone.
One other problem is the tranny when I come to a stop and then leave again it leaves fine. Once first is run up and I let off the throttle and cruise then get back on, it hesitates and then engages kind of harsh back into gear. Almost as if it were slipping! I have a feeling a good flush/filter and fluid change with help with this dramatically.
Other than these problems the car is almost perfect some very minor rust around the back “C” pillar and rough weathered paint. For $400.00 I don’t think I got a to bad a deal.
I want to rebuild the engine to get a little more performance out of it I would like to see if I could get at least 250 wheel out of it just by building up the motor, where do I start and what types of things can I do to get more power out of it? I am planning on tearing it down and having the block crank and heads all checked then having it balanced and if need be having the heads rebuilt.
