Fender Flares ... BIGGER!
NotSoSlowSHO
Gas is $$ WALK!
Moscow, IDASHO!
Holly smokes!
I think the last time I checked this thread was months ago....
:hail: :hail:
This car had better be featured in some magazine or something...
She is looking GREAT!
HoustinoJillian
name's JUSTIN
usa
i would think it would be carpeted on the trunk floor, with some sort of massive system so you won't have to worry about the sides or back cause you won't see them
SHOWYA
TurboSHO Member
Houston, TX
No plans yet for the trunk. I will have 2 10's and 2 amps all Polk/momo brand. So far just the stock carpeting. I do want to have a molded CF box w some nice lighting. I will be sound deadning the trunk once im done with the interior.
The interior still a bit of a hastle ... missing parts such a shift boot, spring loaded door for ash tray in center console.Taking a trip to the junkyard tomorrow!
SHOWYA
TurboSHO Member
Houston, TX
caseywan said:
Any updates???? Gonna have it at Indy???
I dunno ... im ready to put the heads on this week. But i havent even made a reservation yet. I guess i can cruise up there early morning and comback at night. Thats if i have it done by then. Im gona try hustle and get it done!
SHOWYA
TurboSHO Member
Houston, TX
Well the heads are on ... I checked the valve lash after installing the heads and there were no changes ... i had the reference sheet with gaps written down. This is possible right? I know Mikey had mention that they would be off?
Anyway... here are few pics of the engine progress together with my polished front valve cover. Also the adjustable cam gears installed (forgot to take pics of the exhaust gears).
SHOWYA
TurboSHO Member
Houston, TX
No Polished rear valve cover since you wont be able to see it. But i do have these pieces that are polished ...
SuperG
Houston, TX
Are you polishing these yourself? If so, how much time has the polishing taken so far? What else is on your schedule?
SHOWYA
TurboSHO Member
Houston, TX
No, Im having a Pro do it. He charged me 50dlls to do those gave them to him one night and they were done next day.
For schedule im trying to get the engine running by the end of the week. Still have to finish off the interior (some minor parts to put together including stering wheel) but im focusing on getting the car running. I will have take of the crank pulley off since the bolt was loose and check in there. If all is bad then i will have to weld the crank sprocket to the shaft and maybe even the dampner too (maybe a light weight dampner is due?!). I know people have done this before so im really not worried about it since i read that crank cancer is not a problem after welding. I do have 4 woodruff keys that i managed to get new from ford dealer.
NJSHO
Clean Your Shorts!
NJ
Weld the sprocket and dampner to the crank!?!?!?!?!?
How will you change your front main seal?
SHOWYA
TurboSHO Member
Houston, TX
It has been done before like i said ... I guess i will have to change it before the welding.
But i dont know whats going to happen untill i take off the dampner and check everything down there.
SHOWYA
TurboSHO Member
Houston, TX
Yes ... It was a little troublesome installing the speakers. I have 6X9 in the rear and 6 3/4 in the front. The rear speakers are mounted from the inside of the trunk and made new holes. I used a spacer the came with a speker set from alpine. It worked great so the speakers dont hit the rear deck when moving. I took out the old door speakers and cut the bracket in half and mounted the speaker. This speaker is huge it includes a X-over mounted in the inside of the door panel with double sided stick tape and a tweeter. I mounted the tweeter in the speaker grill opening. This is how the install went....
The dash also looks a bit more complete ... just have to put in the A/C unit and the stering wheel.
SHOWYA
TurboSHO Member
Houston, TX
SHO Continental said:
just trailer it there!! this would be awesome to see..
Im really trying to get it done ... but it looks like its coming along nicely....
