Felpro gaskets?
stevetatro
Cincinnati, Ohio
I'm looking for the valve cover/plug well seals gasket set and the intake manifold gasket set; preparing to do some work this coming weekend.
Anyone know where to get them? No AutoZone around me seems to have it...they indicate that the vendor is out of stock.
HELP?!?
Thanks.
naval-avi8or
Chesapeake, VA
Here's the part #VS50378R. Try autozone and just give them the part #. May take them a couple of days to get it. O'Riely or Kragen auto parts. I got the water pump gasket set from Kragen they didn't have it in stock but Fel-Pro is located about 100 miles north of me in Hunnigton Beach CA, they ordered it and had it on Monday and had in on Tuesday. The key is to ask for it by part # because it doesn't seem to be available for all year model sho's, bad cross reference or something.
stevetatro
Cincinnati, Ohio
Oh, I asked for the part numbers. That's all the info they had, was that they're supposedly out of stock and can't be special ordered.
Also, I can't seem to order them online from www.autozone.com.
I don't know what to do now!
SHONUT91
Cameron,Mo.
Just use the part # naval-avi8or gave you and check your local auto parts stores online.This should tell you if they have it in stock or they need to order it for you.hope this helps. :)
<small>[ May 13, 2002, 10:40 AM: Message edited by: SHONUT91 ]</small>
SHONUT91
Cameron,Mo.
You can also try napa online they have them,part #vs50220 but they do not state wether or not the plug well seals are included.Ford parts network is also very expensive. :confused:
smcallis
Hudson, NH
I just went thru this. FPN cannot get the felpro set. Shonut has the set for like 120. Josh is very quick in getting them out. If you order right away I'd bet they'd be here before the weekend.
<small>[ May 13, 2002, 12:31 PM: Message edited by: smcallis ]</small>
naval-avi8or
Chesapeake, VA
stevetatro:
HELP?!?
Thanks.
In your neck of the woods, Kragen is called Checker auto parts. They can get them in just a couple of days if you order them. Should only cost about 60-70 bucks.
KYSHO
Murray, KY USA
I got mine a few weeks ago from partsamerica.com aka Advanced Auto Parts for $95.00 and change.
cRaZySHO.
norwalk, ct usa
If worst comes to worst, let me know. My store has 2 in stock. We could always mail them out to you if you can't find them elsewhere. Ever since we ordered my set, I told my boss to have at least one in stock, just in case I rip or damage one. That way I don't need to wait if I need it asap.
stevetatro
Cincinnati, Ohio
Well, sonofabitch. When I select my car, a '93, it shows no valve cover gasket set available. But, as Scott indicated, when I chose a '91 the Fel-Pro set came up, no problem.
Too bad I ordered it yesterday from www.rockauto.com ($80 instead of $72).
Thanks guys.
