pete c
Well everything's off of the front of the motor for my 60K bottom end. I just got done usin' the wife's hoover on some squirel's acorn stash. The valley between the heads was totally stuffed full of acorns. Not sure exactly how the little bastids got in there, but, I'm thinkin' about rigging some sort of screen to keep them out. I got a piece of quarter inch mesh that would do nicely. If any of you folks ever put your sho away for any period of time, I recommend afew bags of moth balls in various places under the hood.
Anyhoo, I got a few questions. The timing belt on this 93mtx w/93k looks brand new, which I guess is a good sign. The prior owner said it did get regular service, but, there are no receipts. The belt is a PowerGrip the numbers on it are KOA-A3527-00 and 155YG32. Is this the OEM belt? Would re-installing this apparently very good belt be a real dumb way to save 30+ dollars? I'm guessing it is. The T-belt idler spins smoothly, but, it does make a bit of noise and if I spin it as fast as I can by hand, it stops within 2 seconds. Basically, it seems like everything inside is still working OK, but, there is a bit of fine dirt in it.
Any suggestions would be appreciated. It going back together in the morning.
thanks,
pete
thanks,
pete
